Hard to find disply cable
I have been trying to no avail to find a Dell Vostro 3520 LCD display cable. Does anybody have any suggestions? I've tried eBay, Amazon, tried Google searches, and BIng searches so far.
Ist dies eine gute Frage?
The Vostro line is a glorified Inspiron marketed towards small businesses; same guts as an Inspiron except the motherboard flash (you could flash some Inspiron boards with a Vostro BIOS dump, but that may not work with Boot Guard). Knowing that they often use the same model but change the nameplate to Vostro, I got a potential match: 08DCFG (30PIN). It means parts are cheap and plentiful but you depend on the availability for the Inspiron variant of the machine a lot of the time.
Compare your current cable and see; if it's a match, plug the DP/N into Google and find one from a reputable vendor. This does NOT work on motherboards, but for everything else, it's a potential workaround to finding hard to get parts unless they changed something like the color making it a Vostro only version that does not cross match with the Inspiron line.
War diese Antwort hilfreich?
Thank you to both of you. You're information was very helpful. I did find the part eventually. It only took about six hours of searching.
@thomasstrow did you find a part number for it? Sure could help the next person that may be looking for this elusive cable.
Normally for Dell parts I tend to check parts-people.com but it doesn't look like they have they have this cable. Lots of other parts, but not this one. Of course. I will say though, they have pretty good support and it may be worth it to contact them directly, sometimes they have ways to get stuff specifically, and they generally have OEM parts so it may be worth looking into.
Do you have a part number? or an existing cable to pull any part numbers off of?
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 321
