GPU Heatsink temperature does not appear
Guys, is there any way to read the GPU Nvidia 9400m or GPU Diode temperature on the iMac? From what I remember, I could only see the temperature in the High Sierra.
Ist dies eine gute Frage?
Well… I think you found a weakness in the shim service as TG Pro (or likely any temp monitoring app) can’t gain access to the needed firmware API call.
I hit that too with a few custom Apps with OpenCore. Sadly I ended up rolling back to the highest Apple supported macOS my system could use.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 30
Insgesamt: 274
Are you using the latest versions of TG Pro?
von DanJ
@danj Yes, 2.89. From what I remember, I was never able to see the GPU temperature when installing a system above high sierra, using a patch.
In High Sierra I can see the temperature, but in Catalina onwards I can't.
von Ramon Ferreira
@ramonferre18311 - What patch?
von DanJ
@danj At the time of Catalina it was the Catalina Patcher Dosdude1, and currently OpenCore Legacy Patcher, but if I install the official High Sierra I can see the temperature.
von Ramon Ferreira
