Zum Hauptinhalt wechseln
Sony M-430 Microcassette-Corder can record and play back audio. The one-touch recording and two-speed record/playback and automatic shut-off makes this ideal for on the go recording. Model number M430.
Record/playback only works when tape speed is set to 2.4cm
Everything seems to work just fine, albeit the audio sounds a bit wobbly, when the tape speed is set to 2.4cm. However, when i set the tape speed to 1.2cm, nothing works and only the battery light comes on.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @isaakgilissen
Try replacing the drive belt.
Search online for Sony 3-377-420-11 to find suppliers that suit you best.
Also use some Isopropyl Alcohol 99%+ (available from electronics parts stores) to clean the capstan, pinch roller and the record, playback and erase heads in case they're creating a drag on the tape.
Here's the service manual that may help
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Isaak Gilissen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 84
