Zum Hauptinhalt wechseln
Im Juni 2017 brachte Apple die Neuausgabe vom 13" MacBook Air heraus. Es erhielt den neueren Broadwell Intel Core i5 Prozessor, die Leistung und Akkulaufzeit stieg dadurch etwas an.
Mac turns off after a few minutes (even if its charged)
Hi forum!
I have problem with turning off after a few minutes on my MacBook.
It randomly turns off even if its on the charger.
Sometimes i can turn it on back and sometimes it is not running for hours.
Otherwise it's perfectly fine.
Thank you for you answer!
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
how long does it last on battery only?
Have you tried a different charger? - are you using an OEM charger?
is your charging port clean?
von
1. I dont know, it always break down.
2. I tried OEM and not OEM charger and its still dont do anything.
3. Port is clean.
von
Now, after one day, its not even running. I dont know whats with that...
von
Einen Kommentar hinzufügen
1 Antwort
I would install this gem of an App CoconutBattery take a snapshot of the main window and post it here so we can see things.
War diese Antwort hilfreich?
Bewertung 0
5 Kommentare:
I´ll try, but its not running now.
von
does the screen flicker at all? or get slightly brighter?
von
It flicker when its turning off.
von
@robinhoracek - Really need that CoconutBattery output to figure this out.
von
I apologize for my absence. I swapped disk from another of my macbook and it went better. But after a few minutes it turned off again. I will try to get the coconut battery.
von
Antwort hinzufügen
Robin Horáček wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 94
