Is it possible to connect MacBook Pro to a tv
Is it possible to connect the super drive and play the dvd in the tv,I will be obliged to have the procedures.Thanks
Ist dies eine gute Frage?
I pretty sure you can. Idk what the cable is called but I know you use the mini display port or thunderbolt if you have it.
War diese Antwort hilfreich?
Nara, personally I would ask if either of these guys has actually done this on a Mac made prior to 2010. I had to use a MigliaTV product http://www.miglia.com/products/tv.php
to get TV on my Mac and a Videosecu PC to TV Converter VGA to RCA S-Video Mac Computer Laptop to Composite Video Switcher VGA2TV 1L7 to do it.
But I've actually done it, maybe these guys know things I don't.
On the late 2009 iMac and 2010 + products go this way to get from Mini DisplayPort to HDMI: http://support.apple.com/kb/HT4241
On 2009 and back machines with a Mini Display port go this way: http://eshop.macsales.com/item/NewerTech...
It's always possible connecting a recent Macbook to a TV. I don't remember which Video Output has your model (if it's a miniDVI, or a standard DVI, or a Thunderbolt), but there are adapters suited for using VGA or HDMI monitors, and most modern television have VGA and HDMI connection. Place some better loudspeakers, connect the Video-out to your TV and you're set.
You may need an audio cable for sound in addition to the Standard/Mini DVI to HDMI converter cable. Otherwise your MacBook speakers will be used in older models.
I'd sure like to see a link on this on any Mac made prior to 2011.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 727
2 Kommentare
Thanks a lot for all the suggestions,i did connect yesterday and it is working perfectly well
von NARAYANAN LAKSHMANAN
I will try to get older mac try it out and report the matter shortly,in INDIA mac population is not that much like other brands but I will certainly do it and report back to you,I reside in a remote place in southern INDIA and the nearest mac store is 500 kms away
