What would cause the engine warning light to come on
have checked oil ,water and every thing else i could think of but the light is still on is tyere something i might have missed.
Ist dies eine gute Frage?
raylene, a check engine light can turn on because of a large multitude of things. The light turns on because one of the many sensors that monitor the car performance is operating out of range. This sensor will store a code. The code can only be read with an OBD II scanner. Many auto part stores (Autozone or Maaco in CA)will read the code for free. Once you have a code, you can determine much closer what needs to be repaired/adjusted etc. Let us know what you find. Good Luck.
War diese Antwort hilfreich?
not tightening the fuel can cause this. find a mechanic that can clear code. then don't forget to tighten fuel cap. On some cars leaving fuel cap loose causes oxygen sensor to pop a code. Try it never know
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,941
