Zum Hauptinhalt wechseln
Archer AX6000 won't turn on
when i plug it in with the power adapter it came in with, it just wont turn on. there is a slight buzzing noise but no led light showing on the top.
its warranty is already expired and tp-link wont do anything about it.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @evrality
Check if there is 12V DC on the output plug of the adapter to make sure that it is supplying the correct voltage to the router.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
yeah im using the one that came in the box and it is outputting the 12V at 4A
von Teilen
@evrality
Since there are no schematics available for the model, you'll have to open it up and first check that the 12V voltage is reaching the board i.e. possible faulty DC input jack?, and if it is OK then check the board for any obvious component damage etc.
von Teilen
Antwort hinzufügen
Evrality wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 565
