Zum Hauptinhalt wechseln
Repair guides and support for the Elite X2 1013 G3, a highly repairable tablet PC by HP. It's a tablet notebook with a detachable keyboard.
Is this tablet screen can be replaced with screen from elite 1012?
I have hp elite x2 1013 G3 and question is: can I use x2 1012 screen as an replacement for broken screen?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @konradkadej
Short answer is no they cannot be used as they are not compatible. Also they are not the same size so they will not fit correctly in the tablet anyway.
  • Here are the HP Elite x2 1013 G3 Specifications. Scroll down to Display to view the size of the display. Here's the maintenance and service guide for an Elite X2 1013 G3 tablet. Go to p.19 Item #2 to view the HP part numbers for the LCD panels compatible with this tablet.
  • Here are the HP Elite x2 1012 G1 Specifications. Scroll down to Display to view the size of the display. Here's the maintenance and service guide for an Elite X2 1012 G1 tablet. Go to p.19 Item #1 to view the HP part number for the LCD panel.
  • Here are the HP Elite x2 1012 G2 Specifications. Scroll down to Display to view the size of the display. Here's the maintenance and service guide for an Elite X2 1012 G2 tablet. Go to p.16 Item #1 to view the HP part numbers for the LCD panels compatible with this tablet.
Different part numbers would mean different LCD panels otherwise they would use panels having the same part numbers.
Best option is to search online for the part number of an LCD panel that is compatible with your tablet, to find suppliers that suit you best. Usually the part number can be found on the back of the LCD panel itself if you wish to verify that you're getting the correct one.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Konrad kadej wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 123
