Zum Hauptinhalt wechseln
Help! My mac 'Pops' off at switch on!
My white un-web cam iMac takes four attempts to start up, making a 'pop' noise when failing, but then works well although can 'pop off' when woken from a long sleep.
Is it a bad power unit?
Please help!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes, My first guess would be the power supply. Lay it down flat on its screen.. remove the back.. usually if a power supply is "popping" it will have a distinct smell.. also looks for any buldging or swollen capacitors.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
I'm pretty sure it's the power supply because the original power supply that comes with this model is notorious for failure after long use.
von
Could be, but could also be a bad hard drive, use disk utility to verify your hard disk if that's failing, a failing drive can make popping noises.
Bewertung 0
Antwort hinzufügen
Big Dan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 27
Insgesamt: 2,274
