Zum Hauptinhalt wechseln
Reparaturanleitungen, Support und Problemlösungen für das 2022er 13-Zoll MacBook Air, ausgestattet mit Apples M2 Chip. Erscheinungsdatum 15. Juli 2022, Modellnummer A2681
Anyone know y keyboard & trackpad don't work after logitboard reinstal
Does anyone know why the keyboard & trackpad don't work after the logitboard reinstall?
I had a MacBook M2 Air, I cracked my screen and had some water damage, so I decided to remove the logic board and screen for drying.
After a few days, I reinstalled everything in the correct order, but the logitboard doesn't work at all.
Doesn't anyone know why and how to fix it?
Thank you so much.
Ist dies eine gute Frage?
Bewertung 2
9 Kommentare
Do you get any signs of life?
von
Everything works fine just not the keyboard and trackpad, I have to use an externals ones to be able to use my computer
von
@nelsonli i can answer this one for you, but you will need to tell me few answers to my questions:
first of first, did you take the logic board out, and the reinstall it? Or did you replace it? and second of all, did the macbook not turn on after you spilled the water? Also did you spill a glass? or a bit of water? Based on these answers, i know how to help you. Also did you go to apple to get help?
von
Hello Alt name, I only disconnected the battery and reconnected it. I didn't change anything about the logic board. I have a small spill of water and it's dry now. After I disconnected the lid angle sensor, my trackpad and keyboard is back working again.
von
@nelsonli can you open it up and show me a picture of the logic board?
And i'll know if theres any problem, and we can go from there.
also can you start your comment with @altname so i can be notified?
von
4 weitere Kommentare anzeigen
Einen Kommentar hinzufĂĽgen
1 Antwort
Hilfreichste Antwort
I just replaced a MacBook recently and noticed the same thing - make sure you didn’t forgot to connect the very small two ribbon cables into the Zif sockets.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufĂĽgen
Yae wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 397
