Zum Hauptinhalt wechseln
My phone can't turn on, and when I plug it to charge it shows charging
My phone won't turn on, anytime I plug it to charge it shows charging but does not show the percentage
The image above is all I see when I turn it on.
Please I need help guys
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Hp nya muncul logo Samsung terus tapi ga mau nyala
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@kingsleych86979 since it does indicate that it is charging, I would focus on the battery. It is possible that this is an issue with the charging board or the flex cable but then it should not indicate that it is charging. For now, replace the battery.
Since iFixit does not yet have a guide for this, use the one from here It is written in French but hopefully you are using a web browser that can translate it for you.
Replacement batteries are readily available at many online stores.
Now, it is possible that this is an issue with the charging IC obn your main board. For that you would need the schematic and the board layout files so you could do a board level repair, Just remember that a repair like this would require some good tools, excellent skills and experience. So you may have to look for someone around your area that can do it. For now, replace the battery.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Kingsley Chibuisi (De Icon) wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 24
Insgesamt: 624
