Zum Hauptinhalt wechseln
Informationen zu Reparatur und Demontage des Samsung S22 Ultra Smartphones, das im Februar 2022 auf den Markt kam.
network is very slow or almost no coverage after dropping the phone
My phone fell since then and I have only had problems with network and range. Some places not much and sometimes not at all, someone can help me where the problem may be so that I can solve it
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare:
Network reng problem my phone samsung s22 ultra
von
مشاكل في اتصالك بالشبكة.
von
Einen Kommentar hinzufügen
2 Antworten
It seems like dropping your phone may have caused issues with your network connectivity. Here's a brief guide:
  1. Check for physical damage:
    • Dropping your phone could have damaged its internal components, including the antenna or network receiver.
    • Inspect the phone for any visible damage, such as cracks or dents.
  2. Restart your phone:
    • Sometimes, a simple restart can resolve temporary network issues.
    • Power off your phone, wait a few seconds, then power it back on to see if the network connectivity improves.
  3. Reset network settings:
    • If restarting doesn't help, try resetting your phone's network settings.
    • This will remove saved Wi-Fi networks, Bluetooth connections, and cellular settings, so you'll need to re-enter them.
    • Look for "Reset Network Settings" in your phone's settings menu.
  4. Update software:
    • Ensure your phone's operating system is up to date.
    • Manufacturers often release software updates to fix bugs and improve performance, including network connectivity.
By following these steps, you can troubleshoot and potentially resolve the network connectivity issues caused by dropping your phone.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
@tabathakang Blah, Blah, Blah ¯\_(ツ)_/¯ "Nobody's listening to me
Nobody's listening"
Like before. Can the OP fix the device with your Answer? Nope! Your AI is weak
von
olha isso é um problema dessa geração de celulares pós 5g...
infelizmente não é de facil reparo, dependendo da engenharia aplicada no wardware nem tem reparo, devo ter uns 5 dispositivos de direntes modelos e marcas com problema de conectividade semelhantes após quedas, eu indicaria a voce uma assitencia autorizada para que eles troquem a placa inteira.
especificamente esses aparelhos são bem chatos quando dão esse problema ( que geralmenete so piora quando o dispositivo funciona a maios termos ) .
meus pesames mas pela minh aexperiencia e so outra placa ou algum mago do hardware pra substituir metade dos chips do systema de rede.
Bewertung 0
Antwort hinzufügen
Mertcan dincer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 21
Letzte 30 Tage: 65
Insgesamt: 678
