Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
787 Fragen Alle anzeigen
Why is my MacBook typing letter "r" all by itself?
Hi all, my Macbook Pro recently started typing the letter "r" continuously regardless of what program I was in. I can delete them as they are typing but then after a few seconds it will start again. When I am out of all programs and just the desktop is visible the computer makes a noise as if it is trying to type it again. Do you think this is a keyboard problem? I would appreciate any suggestions.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
2 Kommentare
I have this exact same problem. I did clean under my R key but this did not fix the issue? Did you solve it?
von
My problem was caused by the battery swelling up. This caused issues with the keyboard. After replacing the battery ($150) and the keyboard ($100) this solved the issue.
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Yes, this is a keyboard problem. Pop the cap off the R key and see what sticky stuff is holding the key depressed and clean it off. Wet your cleaning cloth lightly first. Never spay any cleaner directly onto your machine.
War diese Antwort hilfreich?
Bewertung 7
5 Kommentare:
Thanks Mayer, there was something under there but, and I feel silly for asking this, but is there a trick to getting the cap back on?
von
Mayer, disregard last question - found a how-to video on Youtube. Letter 'r' problem all fixed. Gotta love the internet! Thanks for your help.
von
UR welcome, come back any time ;-)
von
it doesnt work
von
the problem still occur even after I cleaned up under the cup. pleas help! :(
von
If you got a mouse connected remove it end restart and get a new mouse that mite be the problem
because that is the problem that i had once
Bewertung 1
Mine requires more pressure on the r key than the est.
Bewertung 0
i have the same exact problem with my ‘N’ key. it’s missing off the laptop keyboard, so i have to use an external keyboard, but it won’t stop doing this even still, so any answer will be gladly appreciated.
Bewertung 0
Cleaning the key does not solve the problem for me... unfortunately the ghost typing continues. At the same time, like Lancecharles, it's hard to get the letters to print when I want them (the i and u in my case). The ghost tho will type i's and u's (with accent) at random or stream them until I hit escape.
Like Lotusjohn, i'm using an external keyboard. I just plopped a bluetooth ontop of my mbp with a couple plastic rulers as separating platform between the boards.
Bewertung 0
Antwort hinzufügen
Julie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 5
Letzten 7 Tage: 18
Letzten 30 Tage: 122
Insgesamt: 22,838
