Zum Hauptinhalt wechseln
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
My disc tray button keeps beeping, but the disc tray doesn't open
Even if i try and open the disc tray it doesn't open, i thought the ribbon cable is damaged but the power button is fine, so it's not that, can anyone help? I dont want a digital only Xbox 360.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Is there currently a disc in the xbox 360?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi Filip!
In my experience it still could be the power switch board cable... But it's also possible that your drive is dying.
What do you hear when you try to open the disc tray?
If you don't hear any sounds > power switch board ribbon cable could be faulty.
If you hear the drive trying to open, but it stays shut > faulty drive/rubber belt
Guide for the ribbon cable > Xbox 360 S Frontplatte tauschen
Guide for the drive: Xbox 360 S optisches Laufwerk tauschen
If it's possible to create a video for this and share it with us, that would be great!
Xbox 360 S Optisches Laufwerk Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
40 minutes - 1 hour
Xbox 360 S Frontplatte Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
30 minutes - 1 hour
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
The disctray button sounds like it presses itself, constantly. Its an annoying sound so i might just unplug the ribbon cable and use turn it on using the controller, digital xbox 360.
von
Hi! In my experience (repaired a lot of them) this is caused by the ribbon cable… it’s damaged OR not fully in… best thing to do is to check if it’s probably seated, if this is the case, then replace it for a new one. Good luck!
von
Thanks for the help everyone, but the xbox now has the RedDotOfDeath by accidentally damaging the logic board during an attempt to RGH3 it. Thank you.
Bewertung 0
1 Kommentar:
Hi Filip! Ah, this is hard to fix... Probably for the best to replace the motherboard...
von
Antwort hinzufügen
Filip Reszka wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 88
