Zum Hauptinhalt wechseln
Reparatur- und Wartungsinformationen für den Ryobi 3300 PSI 2,3 GPM Kaltwasser-Benzin-Hochdruckreiniger mit Honda GCV190 Idle-Down-Technologie. Modellnummer: PSI RY8094
Where can I buy the uploader valve
where can i buy the uploader valve
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@wilmeister37410 if you are referring to the unloader valve by the pump, that is part number 310924003
It is widely available since it has been used in many different pressure washers. Available from Amazon to Walmart.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
this is what the cs told me after 5 hours on hold talking to 4 people. he 1st tried to say that i had to buy the whole pump. but ended up verifying the number
von Teilen
the whole problem is they do not have the uploader valve on the parts diagram therefore there is no part number to verify t
he correct fitting of the unloader valves i found
von Teilen
Antwort hinzufügen
WiLmeister wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 442
