Zum Hauptinhalt wechseln
Released in July 2017 with 7th gen Intel processors.
Charging light blinking and not turning On
When i put charging plug in charging light blinks and not starting only blank screen
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I disconnecting the charger, then held the power button on the laptop for 30 seconds and release. Reconnect the charger and checked still not turning on
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @miteshcharoliya
Is it blinking continually or is there a pattern to the number of blinks e.g. 3 blinks > small pause > 3 blinks > pause etc.
A continually blinking power light is an indication that the laptop is in sleep mode.
Try either force stopping and shutting down the laptop by holding the Power button until it shuts down completely and then restart the laptop in the normal way
or
Try opening and closing the lid a few times and check if the laptop comes out of sleep mode by itself.
If still no good try to reset the BIOS to default in case there are any corrupted settings which may prevent the laptop from functioning correctly.
First try disconnecting the charger, if connected and then press and hold the power button on the laptop for 30 seconds and release. Reconnect the charger and check
If still no good open the laptop and disconnect the battery cable from the motherboard, press and hold the Power button for 30 seconds and then release the button. Reconnect the battery, reassemble the laptop, connect the charger and check that it initially charges OK.
Here's a link to the hardware maintenance manual for the laptop.
Scroll to p.37 to view the procedure on how to do this.
If it still won’t charge correctly then you have a motherboard problem
If it starts to charge allow it to charge fully before attempting to start the laptop.
If it starts OK allow it to boot all the way to the Windows desktop and allow the HDD activity to settle before checking things.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I have the same type of laptop 320-15IKB its doing the 3 blinking lights pause and then another 3 blinking red lights while changing it does not turn on but it shows life by charging pleade helo
von
Antwort hinzufügen
Mitesh Charoliya wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 70
Insgesamt: 855
