Why my ASUS ROG can't charge properly?
my laptop only charges when the device turns off, when the device turns on my laptop sometimes charges sometimes don't
Ist dies eine gute Frage?
Hi @vitotaa
Create a battery report to check the status of the battery.
It may be that the battery is failing and the charger can't do both, i.e. run the laptop and charge the battery at the same time.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value as seen in the report.
For a good battery they should be nearly the same value.
You can work out the condition of the battery as a percentage by using the formula: Full Charge Capacity value x 100 ÷ Design Capacity value.
If the battery is <30% you may wish to consider replacing it.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 8
