Zum Hauptinhalt wechseln
Why is my laptop not detecting an external Monitor
I use Lenovo thinkbook and I tried connecting it to another Lenovo desktop monitor using HDMI port but if I do so it's not reacting or detecting anything,how to make it work
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
Hi @soundariya39074
Have you proved that the HDMI connection in the other desktop monitor is working OK?
What is the model number of the monitor or PC if it is an All in One?
von
@jayeff Yes, the HDMI connection is working just fine. I am saying so because my brother uses the same monitor for his MacBook. And it works well for him.
also the monitor's model is Lenovo L-Series 71.1Cm (28") 3840X2160 Pixels IPS 4K Uhd Monitor | 1.07 Billion Colors, 300 Nits, 90% Dci-P3, 2X2W Speakers, AMD Freesync, Hdmi, 360° Revolving and 90° Rotating Screen(L28U-35, Black)
von
@soundariya39074
Try connecting the laptop to another device e.g. TV using the hdmi port in your laptop and check if that works.
Also are you pressing the change display hotkey at the top of the keyboard to change the display output from showing on the laptop screen only, to the external monitor only or to both screens on together?
The key is next to the key with the aeroplane symbol on it
von
Einen Kommentar hinzufügen
1 Antwort
hello and good day,
to answer your question.....different could make you laptop not detect your monitor---
try these fix.....try switching your laptop to external display using the windows key+p and choosing from the options
also ensure that the HDMI cable you are using is in a good condition.....
Then ensure that the graphics driver of the laptop is updated.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Yes, I did all of the steps mentioned above but it is still not working only.
von
Antwort hinzufügen
soundariya lakshmi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 30
Insgesamt: 362
