Thanks for providing the picture of the keyboard and the errors - that's a huge help!
Keyboard:
Honestly, looking at the visible age and wear of the keyboard, I'd guess from experience (professional IT engineer that has troubleshooted a loooooot of machines) that its likely just the keyboard module/keys on it wearing out. Especially as a number of those are commonly and visibly on this machine, higher use.
Have you ever in the life of the device spilled anything on it, especially in that area?
Graphics Driver:
Does the error message contain any additional information at all?
I'd try re-installing the GeForce Experience and then the install if you can, then it looks like this doc from Nvidia seems to help pull logs on that error.
Note: While those steps seem reasonable and appear to be from Nvidia support, anything touching registry or drivers can have risk for your machine, and any/all changes, maintenance, troubleshooting you perform on your machine is at your discretion and risk.
That bit said, I'd likely pull the logs and get more detail than the generic "An error has occurred" GeForce gave you above. ******
Best of luck, and please let us know if you get progress on either of those! ******
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
