Zum Hauptinhalt wechseln
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
20 Fragen Alle anzeigen
Keyboard pressing other keys when only 1 key is pressed
My keyboard was fine until i upgraded my iBook. It now presses more than 1 key for certain keys for example if i type N it comes up with NM or if i type U it comes up with YU any solutions?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
does this happen in all programmes? I had this problem after upgrade too but only on anything using google chrome/windows compatible software, if I used safari/mac programmes I had no problem.
von
It does it even on the login menu so it is keyboard related
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This usually happens after a short in the keyboard. I would remove and reseat the connector cable and make sure you have not left any thing in it that might short it out. To isolate the problem to just the keyboard try using an external USB keyboard and see if the problem is resolved. If all this fails then you'll need to replace the keyboard. Here's how to do that: iBook G3 12 Zoll Tastatur tauschen
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Phillip Wright wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 3,759
