Zum Hauptinhalt wechseln
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
How to remove small stripped, stuck screws to access motherboard?
My 3DS currently has a broken camera, and I am trying to gain access to the ribbon cable on the motherboard. However, the tiny screws in the casing are all either stuck, or stripped. Any tips on how to get them out?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi!
Well, getting stripped screws out can be hard.
What I use is the Precision Screw Extractor Set: Precision Screw Extractor Set
There are many technics, some people are using a rubber band.
Like here: https://www.bhg.com/home-improvement/adv...
Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm. Bild
Produkt
$24.99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
MrKoala wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 47
