Zum Hauptinhalt wechseln
The Chevrolet Tahoe (and its rebadged version GMC Yukon) is a full-size SUV from General Motors. Chevrolet and GMC sold two different-sized SUVs under their Blazer/Jimmy model names through the early 1990s.
On my 2003 Tahoe the driver side power window cable is broken.
How do I replace the drivers side power window cable that is inside the door, seemingly inaccessible. 2003 Chevy Tahoe
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The only fix for a broken cable is to replace the entire regulator. Nobody sells replacement parts for the regulators . To replace a regulator you'll have to remove the door trim panel find a way to hold the glass up and disconnect from the regulator and then unbolt and remove the old regulator . Then reverse the process to install the new regulator
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Long strips of masking tape is actually very good at holding the glass up. Use least 4, and have them taped to the top 12 inches of glass, go over the door, and tape to the top 12 inches on the back of the glass too. It should hold. Used to do that when needed while retrofitting law enforcement vehicles.
von
There really isn't any way to fix just the cable. When a cable comes off the window regulator it's usually because one of the plastic idler rollers has broken . Nobody sells the small plastic parts to fix it . So your best bet is to replace the entire regulator
von
Antwort hinzufügen
Skinnyboy4332 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 47
