Zum Hauptinhalt wechseln
The Xiaomi Mi CC9 Pro (known as the Mi Note 10 globally) Android smartphone has a 108-megapixel camera, 5260mAh battery, and a 6.47" curved AMOLED display. It was released in November 2019.
Xiaomi Mi 10 Lite .after it turns off the screen flashes irregular co
I have hp Xiaomi Mi 10 Lite . I charge my hp, before I charge my hp I turn it off, after it turns off the screen flashes irregular colors. What is the problem.??
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
1 Antwort
The issue you're experiencing, seems to be a common problem among this model. There are several potential causes and solutions you can try:
  1. Software Bugs: Sometimes, software bugs can cause the screen to flicker or flash. Make sure your phone's firmware is updated to the latest version available.
  2. Always-On Display (AOD): Some users have reported that enabling the Always-On Display feature causes screen flickering issues.
  3. Faulty Screen: If the flickering persists and doesn't seem to be related to software, it might be due to a faulty screen. In such cases, visiting a service center is recommended.
  4. Charging Issues: Using a different cable or charger might help. Ensure the charger and cable are in good condition and compatible with your device.
  5. Brightness Settings: The issue might also be related to screen brightness settings. Keeping your screen at maximum brightness or certain brightness levels could trigger the flicker.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Ali wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 439
