Zum Hauptinhalt wechseln
Das ist die 8. Generation des iPads, erschienen am 18. September 2020, erhältlich als 32 oder 128 GB Modell. Die Modellnummer ist A2270.
Charging only works in a certain position, the device's input seems to
Where I connect the charger it seems that there is a bad contact, I have already changed the cable but it continues the same thing, it only works in a certain position
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
لقد قمت بتنظيف مدخل شاحن لكن يستمر بعدم شحنه
I cleaned the charger port but it still won't charge.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi there William, on occasion the Lighting Connector can become junked up with small particles & dust creating for a difficult bond between the power source and the actual lighting port on the iPad. I would attempt cleaning it out very carefully with a toothpick (Nothing that has metal =]) in order to remove any unwelcome dust particles. P.S. the pins for the lighting port are on top so steer towards the bottom when removing the dust.
Hope this helps! Have a wonderful day.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
william lopes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 139
