Zum Hauptinhalt wechseln
Modell A2159, EMC 3301. Eine Neuauflage des Einstiegsmodells des MacBook Pro. Erhältlich in Silver und Space Gray. Erschienen im Juli 2019.
No display, Fans spins & trackpad clicks
Hello everyone,
I've finally come upon another MacBook that has shown no mercy to being fixed so here I am once more. Fortunately it showing minimal signs of life (Kind of like its on life support) but no display no chime nothing visual or audial aside from the fans spinning and the trackpad vibrating. Any advise would be greatly appreciated. TIA!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If the fans are spinning and the trackpad is responding but there are no other signs of life, then you'll need to do some troubleshooting to figure out what's going on. Some things you can do to get more information:
• Test using charger and internal battery disconnected
• Test with external monitor with internal display disconnected
• With the battery disconnected, use an ammeter in-line with the charger to read the amperage and voltage that the system is drawing
• Test power on with other internal components disconnected (trackpad, top case, TouchBar, etc.)
This kind of testing can help you figure out which component is causing the problem. If the issues persist even when you have most components disconnected from the logic board then in most cases you can assume the issue is due to a fault on the logic board.
Good luck!
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Awesome Zach, thank you. I will go ahead and try this and let you know of my findings!
von
@compjinxmagic - To add to Zach’s answer I find a USB-C power meter makes quick work in testing as you can also see how the power logic is responding. The voltage will cycle if things are working internally.
von
Antwort hinzufügen
Corey Meyer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 25
Insgesamt: 184
