Zum Hauptinhalt wechseln
The Lancer is 4 door sedan or 5 door hatchback made by Mitsubishi. The standard model include engine sizes from 1.5-2.4 liters, gasoline or diesel. Transmission options include automatic, standard, and CVT.
Why is my car having trouble turning on?
My Mitsubishi is 2008 lancer and when I try to turn it on nothing happens it a turns on after some time of me trying so can some one help me?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
More symptom descriptions would help. BUT, based on my past experience with my Dodge Charger, you have a bad starter solenoid.
I think all starters work the same. The solenoid has 2 coils, Both are activated when you hit the key to start. One drops out when the started switch is activated leaving the other to hold it in position. If one coil opens, there isn't enough force to pull the bendix in all the way. After a few tries you get lucky and it gets all the way in.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Alex ramirez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 72
