Zum Hauptinhalt wechseln
Reparaturinformationen und Unterstützung für handgeführte Rasenmäher der Toro Company.
My riding mower just died while using! Won’t turn over
I was cutting yard and mower just died. It will not turn over at all. Not battery. I can hear a click when trying to start but won’t turn over to start. Any suggestions on where to look or what to check? TIA!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Starters engage and disengage with a flywheel gear. Starters either have a built in solenoid or an attached one. The battery pushes out the bendix by activating the solenoid using 2 coils. When fully engaged, a switch is activated that supplies power to the starter and opens one of the coils so only one is holding it engaged. Since you hear a click, the solenoid is activating. However, one coil may be open and therefore the solenoid does not fully engage the bendix, or activate the switch. OR the switch is activating and you have a bad starter.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Paul Newman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 181
