Zum Hauptinhalt wechseln
Announced 2020, August 05 Status Available. Released 2020, August 21
How to clean the usb-c port on my mobile phone?
I have problems with the usb.c port of my mobile phone (note 20 ultra 5g), most likely dust. I have seen that one could use a spri on a wooden toothpick (like Stickum), but my doubt is: after using it inside the usb-c port, it will be sticky and then it will be worse. Alternatively, can you list other Stickum-type products that do the same thing but do not damage the mobile phone? Lária compressed I think worse would be a mini but strong hoover as an alternative Other ideas?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @helen40974
Safest option so as to not cause any damage to the USB-C port would be to get an air duster can (examples only) and use it to blow any dust/debris out of the port.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
@jayeff
do you think a can of compressed air or a mini hoover is better? Yesterday I was looking for a hoover (for the house) that doesn't cost much 50/60 euro what do you think? do you have any none/brand to recommend very powerful
von
@helen40974
You could try an ordinary vacuum cleaner, just don't use it for long periods at one time.
If you haven't got a vacuum cleaner and you can also use it for normal vacuuming, then buy one that suits.
If you don't need a vacuum cleaner then buy a can of air. It is more convenient and you don't have to use it all at once, just in case you need to clean the port more often. This may occur if you use the phone a lot in dusty environments etc.
von
Antwort hinzufügen
Helen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 38
Insgesamt: 342
