Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für die 2020er Neuauflage des MacBook Air. Erschienen im März 2020
After I replaced my Battery on my MacBook Air 2020, Battery Connector
After I bought a replacement battery for my MacBook Air early-2020 on iFixit, the battery connector isn’t completely flush with the connector on the motherboard, and so the battery isn’t working, is there any way to fix this issue?
I keep pushing it but I just doesn’t go in fully.
Update (07/27/24)
The system was working before the replacement, and now I am not getting any response but when I plug the computer in, it works, but I’m assuming that doesn’t use the battery, but when I unplug the computer, it just automatically shuts down.
Update (07/28/24)
I cannot download CoconutBattery as the computer is running at a snails pace,
But, I cannot see to find the battery charge icon in the top of the computer, that’s not normal right? Also I cannot find anything related to battery health in System preferences, so I am assuming that the battery isn’t connected to the computer, and the only reason it is on is that it is plugged in to an outlet, as when I unplug the computer, it immediately shuts down, and that the connector is not functioning right. Is that assumption correct, if so, should I ask iFixit for a replacement battery?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
@eddiezhan does your system recognize that there is a new battery, or for that matter that there is a battery at all??
von
Einen Kommentar hinzufügen
1 Antwort
The two halves appear to be butted up, this is as far as it will go. Reference Step 3 image MacBook Air 13" (Anfang 2020) Akku tauschen don’t let the slightly different cable side confuse you as there are a few manufacturers and some are a little different.
Can you tell us if the system was working just before you replaced the battery. Also are you getting any response from the system.
War diese Antwort hilfreich?
Bewertung 0
6 Kommentare:
@eddiezhan - OK, that’s helpful! Let’s see what CoconutBattery tells us. Post a snapshot of the Apps main window, it’s possible you have a bum battery.
von
@eddiezhan - What happens when you plug in the original battery? Does that work correctly? If you have a second system you should be able to use it to gain access to CoconutBattery to then transfer via a USB drive.
As the system is running slowly thats telling us SMC is in CPU Safe Mode! Time to run the onboard diagnostics! Restart the system and press the D key which is one of the Startup keys
Mac startup key combinations Let us know what you get. Its possible one of the other cables didn't quite connect or the battery is bad.
von
I tried to press the D key, and the diagnostics are not loading, but when I plug in the old battery, the computer works, so I think the battery connecter is just bad, how should I return the battery?
von
Do I just ship the battery back, or do I need to contact iFixit; how should I return the battery?
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Eddie Zhan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 141
