Zum Hauptinhalt wechseln
Veröffentlicht am 24. Oktober 2011 / 2,2, 2,4, oder 2,5 GHz Quad-Core Intel Core i7 Prozessor
Blue screen always show when booting recovery mode
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
@brightseyr58352 Did you ever try to install windows on it? Or did you ever 'Patch" it to Catalina? I ask this because I have the same issue.... I can answer this question if so.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Do you have trouble booting into anything else? The symptom sounds like it could be due to a failing GPU on the main logic board, which is unfortunately extremely common for the 15-inch 2011 MacBook Pro model. You may need to replace the logic board to resolve the issue if that is the problem. You could also try resetting the SMC and NVRAM, or you could try booting into Internet Recovery Mode instead. Good luck!
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
@livfe - And I’m now Zach?
You need to control your own comments and stop dictating what fits where.
von
Antwort hinzufügen
Bright Seyram Pongo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 16
Insgesamt: 114
