Zum Hauptinhalt wechseln
27" Display mit einer Auflösung von 2560 x 1440 Pixel und Thunderbolt & MagSafe Kabelbefestigungen
power supply board replacement part
i'd like to get a power supply board (flextronics) for my 27" thunderbolt display. are these for sale? are they same is what is in a 27" iMac?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
7 Kommentare
Hi aaronoehlke. Did you find the power supply board for sale?
von
I also need this - it makes a weird noise - and it is coming from the power supply...
von
Have you got the power supply?
von
Hi Karsten,
Nope - have you got one in Denmark?
von
Unfortunatly not!
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
This should still be under warranty. If it is, I would certainly get the extended AppleCare warranty.
War diese Antwort hilfreich?
Bewertung 3
Hi
Power supply board part numbers are: 661-6048, 661-5543. I found boards available for sale on ebay and maybe available for other apple spares suppliers if you search using the part numbers.
Bewertung 3
2 Kommentare:
Will both power supply board with the different part numbers be compatible for a Thunderbolt Display?
von
The question is still open, are those part numbers interchangeable or: what's the difference?
von
Antwort hinzufügen
aaronoehlke wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 21
Insgesamt: 7,023
