Zum Hauptinhalt wechseln
Veröffentlicht im April 2010 / 2,4 GHz, 2,53 GHz Core i5 oder 2,66 GHz, 2,8 GHz Core i7 Prozessoren
Why can't I manage to install a new macOS (high Sierra)
This mac would not boot every time I switched it on, it would show a file icon with a question mark, whenever I try install High Sierra or any macOS thought to be compatible with this Macbook pro 15 mid 2010, it just switches off and restarts while in the last process which is installing the macOS . What is wrong? Is it a hardware issue or a software issue?
I reached a point where I was able to install the high sierra and it would work fine but the issue continued, it became normal for it t last approx. 10s before it switches off again. So because of frustration I started the process again but now I'm back to square 1.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
When installing and wiping the drive in disc utility be sure to check the 'show all devices' and select the TOP layer of the drive that is to be wiped, this will clear all data partitions correctly and help with a smoother install (this is often overlooked).
von
Einen Kommentar hinzufügen
1 Antwort
Let’s dig a bit deeper here… What is the make and model of your drive?
You can face both hardware and file structure issues within the install process.
I do recommend setting up a bootable OS installer so you can fully wipe the drive if the drives file structure is messed up.
Download from here a fresh copy of the OS from another Mac system How to download and install macOS then follow this guide to setup a bootable 32GB USB thumb drive Create a bootable installer for macOS
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Humbotron wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 146
