Zum Hauptinhalt wechseln
Reparatur-, Demontage- und Fehlerbehebungsinformationen für das Microsoft Surface Pro 11. Das Gerät wurde im Juni 2024 mit der Modellnummer 2076 veröffentlicht.
Replacement M.2 Screw for Surface Pro 11
I stripped out the screw on my brand new Surface 11 (it turns out it must have been a 3IP Torx head). I'm having trouble locating where to purchase a replacement (M1.2 x 2/2.5) screw. Microsoft wanted me to send the Surface back in, which is silly for a 'servicable' part. Thanks in advanced.
iFixit Precision 4 mm screwdriver bits. Replacement bits for the Pro Tech Toolkit, Mako Driver Kit, and Manta Driver Kit. Bild
Produkt
iFixit Precision 4 mm Screwdriver Bit
$2.99
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
It probably feels a bit like overkill, but the screw is included in the $18.99 "Surface Pro 11 OLED Consumables Kit" available from this site. It's the only place I've been able to find one.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Thank you so much. Now I just need to figure out how to get the screw out. It needs a special screwdriver. I used what seemed like an appropriate sized Phillips head and it’s now stripped of any threads and I’ve had no luck getting it out. Tried the rubber band trick. Ordered a screw extractor. :-/
von
Which site please..?? Same problem here.
Three days old surface pro 11 ans stripped the screw while upgrading the screw.
von
Bewertung 0
Did anyone have any luck finding the screw outside of the $20 kit?
Bewertung 0
Antwort hinzufügen
Albert Einstein wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 9
Letzte 30 Tage: 29
Insgesamt: 1,669
