Zum Hauptinhalt wechseln
Repair guides and disassembly information for Honor's Android-based smartphones. Get everything you need to repair your Honor phone yourself.
لماذا ينفذ شحن البطارية سريعا؟
الشحن ينفذ من البطارية بشكل سريع حتى بدون استخدام عالي للهاتف ( هاتف honor 8x)
Translation Arabic - English
Why does the battery drain quickly?
The battery drains quickly even without heavy use of the phone (Honor 8X phone)
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
@wgameil this can be caused by applications running in the background, or bad settings like enabling push email as well as a bad software update. It can also be caused by a bad battery.
Try this
Shut down all background apps when not in use via the Recent Apps button and select the delete icon to close all running apps
- Settings > Connections > More Connection Settings > Nearby Device Scanning > Off
- Turn off Wi-Fi, Mobile Data and Bluetooth when not in use
- go to Settings > Battery (or Optimizer > and enable Power Saving mode
After that you want to try to clear your phones cache.
If none of that works, it's time to replace the battery. Since iFixit does not yet have a guide for that, use this one It was written in Spanish, so use a browser that does the translating for you, if needed. Replacement batteries are readily available at plenty of online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Translation
@wgameil قد يكون السبب في ذلك هو تشغيل التطبيقات في الخلفية، أو الإعدادات الخاطئة مثل تمكين البريد الإلكتروني الفوري، فضلاً عن تحديث سيء للبرنامج. وقد يكون السبب أيضًا هو بطارية تالفة.
جرب هذا
قم بإغلاق جميع تطبيقات الخلفية عندما لا تكون قيد الاستخدام من خلال زر التطبيقات الأخيرة وحدد أيقونة الحذف لإغلاق جميع التطبيقات قيد التشغيل
- الإعدادات > الاتصالات > المزيد من إعدادات الاتصال > مسح الأجهزة القريبة > إيقاف
- قم بإيقاف تشغيل Wi-Fi وبيانات الهاتف المحمول والبلوتوث عندما لا تكون قيد الاستخدام
- انتقل إلى الإعدادات > البطارية (أو المحسن > وقم بتمكين وضع توفير الطاقة
بعد ذلك، تريد محاولة مسح ذاكرة التخزين المؤقت لهاتفك.
إذا لم ينجح أي من ذلك، فقد حان الوقت لاستبدال البطارية. نظرًا لأن iFixit ليس لديه دليل لذلك حتى الآن، استخدم هذا لقد كُتب باللغة الإسبانية، لذا استخدم متصفحًا يقوم بالترجمة نيابةً عنك، إذا لزم الأمر. تتوفر بطاريات بديلة بسهولة في العديد من المتاجر عبر الإنترنت.
أثناء عملك على هاتفك، التقط الكثير من الصور. بمجرد الانتهاء من ذلك، التقط تلك الصور وإنشاء دليل لـ iFixit. سيساعد ذلك الشخص التالي الذي يواجه نفس المشكلة التي تواجهها. من السهل والممتع إنشاء هذه الأدلة. https://ifixit.com/Guide/new سيقدر مجتمع iFixit هذا.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
W gameil wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 141
