Zum Hauptinhalt wechseln
My laptop is showing only 1 ram when I have two installed
My laptop is only showing 1 ram slot working of 8gb whereas I have 2 8gb rams installed which earlier showed 16 gb in total but one day when I was going through the laptop it started showing only 1 slot and stated that my laptop has only 8 gb ram
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @shivanshyadav
It could be faulty ram or a faulty ram slot.
What is the full model number of the laptop as seen on the product information label on the bottom of the laptop?
Knowing the model number will help to find the manual so that you can read how to open the laptop and safely remove 1 ram module at a time and check if the laptop works or not and if it works with either one of the modules installed, to try the other slot to see if that works.
Update (08/11/24)
@shivanshyadav
Here's the maintenance and service guide, taken from this support webpage for the model.
Go to p.31 to view the procedure to remove/replace the memory modules.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
The model number is 15-ec1512AX
von
Antwort hinzufügen
Shivansh yadav wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 270
