Zum Hauptinhalt wechseln
Repair guides and disassembly information for Apple's 4th generation 11" iPad Pro. Released October 18, 2022.
iPad Pro 11" 2022 does not charge. The connector has been replaced.
The iPad periodically did not charge and stopped charging at all. I disassembled it and charged the internal battery. The iPad turned on and works fine except for charging and data transfer via cable. I replaced the connector. I examined the old one carefully and I do not rule out that the contacts on it were damaged and shorted out. With the new connector, the iPad also does not want to charge. I checked the USB-C tester and I see that the VBUS line is faulty, but I do not have a diagram to trace the path of this line and decide on further repairs.
Voltage on the port is 5V, current fluctuates around 0.2A.
Perhaps someone has a diagram of at least previous models to suggest where to look for the problem? Can you advise anything?
Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
I am having the exact same problem as your device. I wanted to change the charging port, but after I saw your comment I stopped. What do you recommend I do?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
Found this site that sells schematics with a listing for 3rd gen 11” Pro.
https://laptop-schematics.com/db/74/iPad...
Might be what you’re looking for.
Hope this helps
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks, but I hope to find a cheaper solution.
von
Antwort hinzufügen
Info wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 1,095
