Zum Hauptinhalt wechseln
The Dodge Avenger name returned in February 2007 as a 2008 model year sedan to replace the Dodge Stratus, whose coupe version had replaced the original Avenger in 2001.
How can I change the headlights on my 2010 Dodge Avenger?
I want to change the headlights to put in new ones, but I can't find where to remove them. Other than that, the headlights point up, does anyone have a solution for those two problems?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @fixther22
Here are the sections from the 2008 Dodge Avenger repair manual that may help. They are also applicable to the 2010 model.
2008 Dodge Avenger Lamps And Lighting Exterior
Go to p.7/61 onwards to view how to align the headlamps.
Go to the bottom of p.58/61 to view the procedure to remove the unit -front lamp. The fascia removal procedure is shown in the 2008 Dodge Avenger Frame And Bumpers section.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
fixther wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 179
