Mein S23 Handy wurde durch Salzwasser zerstört.
Laut Reparaturwerkstatt der Versicherung unreparierbar. Leider waren für mich wichtige Bilder drauf. Kann man da irgendwie drankommen? Wo ist der Speicherchip zu finden?
Ist dies eine gute Frage?
@jaegerstefan you can't pull any information of the memory IC's without having the phone come on. The memory and the rest of the phone are coded to each other. If you can't turn your phone on long enough to recover the files from it, consider everything on the internal storage (memory) a loss.
I would not rely on this "Laut Reparaturwerkstatt der Versicherung unreparierbar", since it is very common for any repair shop to NOT repair water damage. Remember, water damage is the least likely repair to succeed. For a repair shop it is also not lucrative. The time it takes to troubleshoot and to repair this is often times greater then the cost for a new phone. That is where the insurance will always say, no.
I suggest that you try and do it yourself. I mean at this point, you really have nothing to lose.
The very first step I would take is to disassemble your phone. You can use the teardown from here and you can use the specific guides from here They are written in Spanish, use a browser that does the translating for you. Next, remove the main board and the charging board. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board.
Take a close look at all components and connectors. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Since this was a salt water immersion, you need to clean it first with plenty of distilled water. Once you got any gross contamination cleaned, use +90% isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use distilled water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water.
The importance here is the cleaning. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Let us know if this did yield any success. Sometimes even a reflow with a hot air rework station and plenty of flux after cleaning, will help as well. I would even go ahead and instead of cleaning the charging board, I'd replace it. It just increases the chance of a successful repair.
Best of luck and let us know how it works out for you.
Repair is War on Entropy!
Translation
@jaegerstefan du kannst keine Informationen von den Speicher-ICs abrufen, ohne das Telefon einzuschalten. Der Speicher und der Rest des Telefons sind miteinander verschlüsselt. Wenn du dein Telefon nicht lange genug einschalten kannst, um die Dateien daraus wiederherzustellen, betrachte alles, was sich auf dem internen Speicher befindet, als Verlust.
Ich würde mich nicht auf diese „Laut Reparaturwerkstatt der Versicherung unreparierbar“ verlassen, da es sehr häufig vorkommt, dass eine Reparaturwerkstatt Wasserschäden NICHT repariert. Vergiss nicht, dass Wasserschäden am unwahrscheinlichsten zu reparieren sind. Für eine Reparaturwerkstatt ist er auch nicht lukrativ. Der Zeitaufwand für die Fehlersuche und Reparatur ist oft höher als die Kosten für ein neues Telefon. In diesem Fall wird die Versicherung immer nein sagen.
Ich schlage vor, dass du versuchst, es selbst zu reparieren. Zu diesem Zeitpunkt hast du wirklich nichts zu verlieren.
Der allererste Schritt, den ich machen würde, ist, dein Telefon zu zerlegen. Du kannst den Teardown vom hier und die speziellen Anleitungen vom hier Sie sind auf Spanisch geschrieben, verwende einen Browser, der die Übersetzung für dich übernimmt. Als Nächstes musst du die Hauptplatine und die Ladeplatine ausbauen. Du musst alle EMI-Abschirmungen entfernen. Wenn du die Abschirmungen nicht entfernst, reinigst du die Platine nicht.
Sieh dir alle Komponenten und Anschlüsse genau an. Achte auf starke Korrosion, überprüfe die Stifte in den Steckern usw. Wirf einen Blick auf alle Steckverbinder und Kabelenden. Da das Board in Salzwasser getaucht war, musst du es zuerst mit reichlich destilliertem Wasser reinigen. Wenn du alle groben Verunreinigungen beseitigt hast, kannst du die Teile mit 90 %igem Isopropylalkohol noch einmal reinigen. Für die richtige Reinigung verwende [Anleitung|5825|diese Anleitung]. Sie wurde für ein Apple iPhone 3G geschrieben, aber alle Schritte sind auch für dein Handy relevant. Ich kann gar nicht oft genug betonen, wie wichtig eine gute Reinigung ist, also führe sie immer wieder durch und ersetze den Alkohol nach jeder Reinigung.
Verwende für die Reinigung keine Druckluft, denn dadurch können sowohl Flüssigkeit als auch Korrosionspartikel in Bereiche gelangen, die später Probleme verursachen. Verwende kein Trinkwasser. Wenn du Wasser verwenden musst, nimm destilliertes Wasser. Außerdem musst du es nicht einen Tag lang trocknen lassen. Isopropylalkohol in der höheren Konzentration wird schnell verdunsten und das Wasser auflösen.
Wichtig ist hier die Reinigung. Am besten ist es, sie mit einem Ultraschallreiniger zu säubern, aber wenn du keinen Zugang zu einem solchen hast, wird das zumindest helfen. Vergiss nicht, die Batterie auszutauschen. Das ist ein Muss und keine Option. Er wird kaputt gehen, wenn du dich nicht sofort darum kümmerst.
Danach baust du dein Telefon wieder zusammen und bewertest es neu. Solange du dein Board nicht gereinigt und den Akku nicht ausgetauscht hast, ist alles nur eine Vermutung. Denke daran, dass Wasserschäden am schwierigsten zu beheben sind. Es spielt keine Rolle, ob das Board 2 Sekunden oder 2 Stunden lang Wasser ausgesetzt war.
Sag uns Bescheid, ob dies zum Erfolg geführt hat. Manchmal hilft auch ein Reflow mit einer Heißluft-Rework-Station und viel Flussmittel nach der Reinigung. Ich würde sogar so vorgehen, dass ich die Ladeplatte nicht reinige, sondern sie austausche. Das erhöht die Chance auf eine erfolgreiche Reparatur.
Viel Glück und lass uns wissen, wie es dir ergangen ist.
Reparieren ist Krieg gegen Entropie!
Anleitung
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
Anleitung
Schwierigkeitsgrad:
Mittel
War diese Antwort hilfreich?
Hallo @jaegerstefan !
Ich bin mir jetzt auch nicht sicher, ob sich da noch was retten lässt, aber du könntest mal diese Schritte versuchen: Electronics Water Damage.
Wenn du die Bilder auf der SIM-Karte gespeichert hattest, die kannst du hier ausbauen: Galaxy S23 Teardown.
Ich hoffe das hilft dir ein bisschen weiter!
Hallo zusammen.
Leider hat es keinen Erfolg gebracht. Das traurige ist, meine Fotos sind unwiderruflich dahin.
LG
Stefan
Oh, das tut mir voll leid...naja, es sieht so aus als hättest du für den Moment alles versucht. Vielleicht behältst du es ja noch eine Weile, man kann nie wissen, ob sich im Lauf der Zeit noch eine neue Möglichkeit ergibt.
@jaegerstefan sorry to hear this. IF you can post some well-focused pictures of your motherboard. Let's see if we can see anything odd and can help you further. Also, let us know the exact model number for your phone. Let's see if schematics are available.
@jaegerstefan, das tut mir leid. Wenn du kannst, poste ein paar gut fokussierte Bilder von deinem Motherboard zusammen mit deiner Frage. Mal sehen, ob wir etwas Ungewöhnliches erkennen und dir weiterhelfen können. Gib uns auch die genaue Modellnummer deines Telefons an. Mal sehen, ob Schaltpläne verfügbar sind.
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 202
