Zum Hauptinhalt wechseln
The Honda Fit, also marketed as the Honda Jazz, is a five-door, front-engine, front-wheel drive B-segment subcompact car manufactured and marketed by Honda since 2001 and now in its third generation. Marketed worldwide and manufactured at ten plants in eight countries, sales reached almost 5 million by mid-2013.
20 Fragen Alle anzeigen
Can't insert underdash fuses
I am trying to replace 3 fuses for 3 windows. I got the old ones out with the help of the fuse puller, but I can't get the new ones in. Large hands, really hard angle. I can see where they should go in, but they won't, and I'm afraid to push too hard for fear of damaging something. Does anyone have any advice? Thanks in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@johnb12099 if you have the proper fuses that are compatible with the ones you removed, the only way is to line the fuses up with the contacts and push hard. Now, the other possibility is to find somebody with smaller hands in your social circle and see if they can help you with that. Otherwise, I would try a "shade tree mechanic" and see if they would do it for you. Might cost you a few $$ but may work in your favor.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
John B wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 21
