Zum Hauptinhalt wechseln
Kabellose Multitouch-Maus der zweiten Generation, von Apple am 14. Oktober 2015 veröffentlicht. Modell A1657.
Cursor not moving properly
I have bought this mouse around 3 years ago. It worked perfectly well until I accidentally dropped it on a hardwood floor. Since then the cursor won't move well and would move and stop when I move it around. Before dropping it it would work well and I could move it around and it would not get stuck or glitch. Now it's so hard to use it that I started using my trackpad. When I shake it I hear something moving inside it. I need help! This thing cost $100, and I don't want to cause my mom a burden. Anyway, I can fix it myself or is it possible for a technician to fix it?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Carefully use a puff of can’ed air into the lens area underneath to blowout any dust which is now blocking the view of the detector. Sometimes the debris is within the light tube for the detector which is not easy to get to or you knocked the detector loose.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
doki ail wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 29
Insgesamt: 292
