Dyson V15 Detect stops after a few seconds with no indicators
I've had it for nearly 2 years. The problem occurs when I press the trigger—it runs for a few seconds and then stops (with its signature "wooump" sound). It repeats this 2-3 times before eventually working. However, now I can't get it to run for longer than a few seconds, even after several tries.
I’ve changed the filter and cleaned everything I can access. In some forums, I’ve read that it might be an issue with the "main body," (whatever that means) while others suggest it could just be a cracked trigger, which should be an easy fix.
Ist dies eine gute Frage?
1 Kommentar
How many of the capacitors are there in the v 15 as I have exactly the same problem have found them on line (upgraded that will do the job ) so just need to know how many to order many thanks Ian
von Ian Green
