Zum Hauptinhalt wechseln
The Craftsman Pressure Washer 580.752710 is a gasoline-powered cleaning machine that generates up to 2550 PSI of water pressure and has a flow rate of 2.3 GPM. It features a 190cc engine, a pump with a thermal relief valve, two 32-ounce detergent tanks, a 25-foot high-pressure hose, and a spray gun with four nozzles. This page provides further details and repair information for the product.
How much oil goes in the pump?
How much pump oil goes in the pump
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@look slike it is not written down anywhere. In that case I suggest you change it as directed by the manual:
Pump Maintenance
Changing Pump Oil
Change oil every 50 hours or once yearly, whichever occurs first.
Change pump oil as follows:
1. Drain engine oil and fuel from pressure washer.
2. Use a 8mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tilt pressure washer to drain oil into an approved container until it drips slowly from pump.
4. Tilt pressure washer in opposite direction and empty "premeasured pump oil bottle" into same opening (a small funnel may be helpful).
5. Install black pump oil cap and tighten firmly.
Instead of using a "premeasured pump oil bottle looks like around~5oz" I get a small funnel and uses that to add oil until the level is just below the drain hole. It might also be useful, to measure the amount drained (pour it into an old measuring cup). That way you know how much you should add.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Big papa wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 24
Letzte 30 Tage: 111
Insgesamt: 369
