Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2010 / 3,06 & 3,2 GHz Core i3 oder 3,6 GHz Core i5 Prozessor
Housing/ stand compatible with 2009 iMac?
I previously had a 2009 imac, which the display randomly broke on it giving me grey screen no matter what. I have now purchased a 2010 iMac which has a broken stand. is it possible to swap the housings and/or stand between the 2? also i assume that my ssd from the 2009 is just plug in and works right? or do i need to do extra work?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It’s a far amount of work to get to the hinge which is inside the housing. Even still that’s what I would do.
As far as your SSD that should be fine. Depending on what the new system has for RAM I would boost it to 16GB while in there.
Basically, just follow this guide as the foot hinge is just behind it iMac Intel 21,5" EMC 2389 Logic Board austauschen
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Sam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 26
Insgesamt: 109
