Zum Hauptinhalt wechseln
Repair guides, disassembly, and troubleshooting information for the fourth generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-040.
L3 button (sprinting) does not work after change of potentiometer
Hi,
Changed my potentiometer (left joystick) and it works great after the GUI installation. BUT, the toggle on the L3 does not work. I can’t sprint, and I have disassembled the controller 10 times, can’t see anything wrong. I really think I did a great job!
What to do here?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
How do I fix stick drift on my controller
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi!
Are you sure that it makes good contact inside the joystick? Maybe it's not pressing all the way in.
Can you share some pictures with us?
Anyway, if you tried everything and you just won't get it to work, I would just replace the left joystick. Saves you a lot of investigating and headache. And when you are there, maybe easier to replace it for a hall effect joystick?
War diese Antwort hilfreich?
Bewertung 3
15 Kommentare:
Yeah, I will try to post some pictures here this afternoon.
I’m thinking of byuing the gulikit joystick!? A bit expensive though. Feels like I could have just bought a new controller buy now haha.
von
Yeah those are great. They are more expensive but it's worth it. I fully understand yes haha. It's probably for the best to replace it tho..
von
It did not work so it must be the that little solder spot missing the cooper-ring,but we found the issue!
It is the same issue again everything works except Toggle L3 (B10 on gamepad tester).
So how do i find the right traces?
von
Indeed, the issue is found!
Here you can find some more info about that: https://www.reddit.com/r/soldering/comme...
von
[image|3429584]
von
10 weitere Kommentare anzeigen
I bought a secondhand controller with the right gen and switched the motherboard to match the controller. Works great!!
I think I &&^&@@ it up doing to much soldering on the solderpoints and ripped the copper ring.
Bewertung 0
Antwort hinzufügen
Joakim Loso wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 24
Letzte 30 Tage: 99
Insgesamt: 2,612
