Zum Hauptinhalt wechseln
Informationen zur Reparatur und Demontage der kabellosen Gaming-Maus G Pro X Superlight von Logitech. Identifizierbar anhand der Modellnummer MR0106. Veröffentlicht im Dezember 2020.
Scroll wheel not working after installing a replacement.
The middle click was not working on the mouse so I got a replacement. After the replacement, the wheel stopped working and the middle click didn't improve also. This was also the same with the old button board.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
You say you got 'a replacement' but do not specify for what: a replacement for the 'middle click' sounds strange.
Two things can go wrong here.
  1. The middle click not working: If you open the mouse you'll find the wheel shaft rests on a small micro switch. Determine if it seats properly and if you can hear a 'click' sound when pressed.
  2. If the wheel doesn't scroll, here's what I found on mine: A plastic wheel with a soft plastic/rubber 'tyre' (or tire in American spelling) covering it. My tire was slipping on its wheel - both very smooth - and the tire wasn't a tight fit any longer. I roughened up the wheel a bit and dabbed a drop of super glue on the wheel bead then re-fit the tire - problem solved.
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
I replaced the hole button assembly the above is a link to what I bought
von Teilen
I also, feel the click
von Teilen
I can also feel the notches when I spin the wheel
von Teilen
Antwort hinzufügen
james1998hodges wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 53
Insgesamt: 679
