Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für die 2020er Neuauflage des MacBook Air. Erschienen im März 2020
Went through charging discharge process now overheating fan constantly
Macbook air 13 early 2020 A2179 battery fully charged after replacing plus 2hrs then ran it down to fully discharged until unit shut off then fully charged to 100% again now after using the computer the fan constantly runs charging percentage rapidly drops and unit is getting hot? not charging after replacement
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Can you install CoconutBattery so we can see what’s happening with both the battery and the charging of it. Post a snapshot of the Apps main window here so we too can see.
von
Einen Kommentar hinzufügen
1 Antwort
Try reseating the battery connection to the main logic board (make sure the end of the battery connector is flush with the end of the connector on the logic board). Then reset the SMC and PRAM and reboot the system. If the issues still persist, there may be a larger problem with your device or a problem with the battery you installed. Good luck!
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
@zpl - Let’s see what CoconutBattery tells us.
von
Antwort hinzufügen
Michael A Pitruzzello Jr wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 35
