Zum Hauptinhalt wechseln
Das ist die Variante ausschließlich mit Wi-Fi der fünften Generation des iPad, erschienen im März 2017. Erhältlich mit 32 und 128 GB Speicher, einem 9,7" Retina Display und einem 64 Bit A9 Prozessor.
Number 2 on each screen that is permanent
I replaced the digitizer on a 5th gen iPad with a new one from ifixit, but now there seems to be a number 2 on the screen that is up near the top right near the battery indicator. it is sideways and very small, and is on each screen in the same spot, even when watching videos.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Amazing, I couldn't even tell that there was a plastic film on the digitizer. Thank you so much, that was it.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
When replacing an LCD or Touch glass both come with this protection and it’s easy to miss removing one.
The touch glass has one either side and the LCD one is sometimes cut so close to the edge that it looks like it’s part of the LCD and not there.
These protective films can have small manufacturers stickers or markings on them that are not always easy to see.
I’m guessing that your problem is one of the plastic films haven’t been removed.
Hope this helps
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Mike Joyce wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 94
