MacBook 6.1 very slow after battery removal.
Hello, I tried to revive my macbook 6.1 lately but I did notice a bump in battery that prevented touchpad from clicking, so I removed it to work it from the wall.
But while I was trying to update to the latest OSX, I did noticed the performance was horrible, I found out the kernel_task was going like 700% CPU usage in activity monitor and after some digging around that means the laptop is throttling.
I checked my temps they are fine (used ol good istat pro) so I couldn't figure out the problem, and then someone on reddit suggested to check the thermal sensor in the battery, which honestly didn;t even knew existed.
I will try to check once I'm back at office although the system is so slow that it is a pain to do that.
In the meantime I wanted to ask, if let's say the removed with the battery sensor indeed is giving some crazy readings, is there a way to stop the system from trying to read from it?
THank you!
Update (10/09/24)
@danj Hey so as I love fire hazards I decided to go MacGyver and open up the old battery, and removed the module that was getting a bit fat.
Soldered the 2 ends to close the circuit and installed it again on the macbook.
So far it is working, the system reports weird numbers on capacity but the temp is good (sensor working), no burning smell, no hot spots on hand. Well I guess it somehow works.
Given the way I'm planing to use this system I don't expect it to have any trouble and not catch it immediately. I will monitor it for sure but this is just an old system that I play around with, I will probably try to hack sonoma on it and then again reinstall OSX 10.6 to keep as vintage system around (the last OSX to have rosseta).
Thanks for your input!
edit: not that the mac performs normally I was able to look a bit more around with the opencore legacy patcher, to my surprise there is an option to disable through the installer the firmware check for the battery!
So if everything went ok and I'm able to install a newer macOS I could also have the battery removed again to be safe from my tampering.
Ist dies eine gute Frage?
1 Kommentar
@nitro912gr - While it’s not what I would do, if it works then that’s all that matters!
von DanJ
