Why is fuel leaking from the back of the carborator
Fuel leaking from behind carborator
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Hey there, can you tell if the leak is coming from the actual carburetor itself, or is the leak between then where the carburetor connects to the cylinder head?
von
A stuck float or bad gasket if your plug is getting fouled out it's probably the float tap it lightly with a hammer and also usually it will run crappie with a bad gasket.
von
Einen Kommentar hinzufügen
