Zum Hauptinhalt wechseln
Reparaturinformationen und -anleitungen für die lang ersehnte Neuauflage des beliebten MacBook Air, ausgestattet mit Intels Core i5-Prozessoren, einem aktualisierten Retina-Display und zahlreichen weiteren Änderungen und Updates, veröffentlicht am 7. November 2018.
Charging Pin only connects when restart
Hi everyone! I got this MBA A1932 and about a week ago my battery didn't charge at all, did a little inspection on the inside and found no damage like corrosion or broken connectors.
However, when I boot it up it started charging again until I disconnect it and then it won't charge until I restart the MacBook, also, for data both pins works fine (a little slow sometimes) even when disconnecting and connecting again.
Did some SMC and NVRAM restart but had no effect on it, also noticed that the battery cycles are very high (~1500) and got the maintenance warning.
Will replacing the battery solve the problem? or maybe is related to the pins themselves?
Already ordered a new battery and run some test but would like to know if this is gonna solve it or should I repair something else. Is there a program to run to diagnose this kind of issues?
EDIT:
Some captures from coconut battery after battery replacement
-With charger connected from start
-With charger disconnected and immediately connected again
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
If you restart your system and then press the D key you will enter into diagnostics. Mac startup key combinations
With such a high cycle count it’s safe to say the battery needs replacement for sure. I would recommend installing this useful tool CoconutBattery it’s my goto to understand what’s happening between the battery and its charging.
War diese Antwort hilfreich?
Bewertung 0
12 Kommentare:
Thanks, definitely will try this app. About the Apple Diagnosis, I forgot to mention that also did that but only warn me about the battery, nothing about the pins themselves.
von
@alejandrop15221 - Then the battery is your focus, don’t get distracted.
von
I finally replaced the battery, however, the problem remains. I did a complete SMC and NVRAM after the new battery was installed. I did run test with coconut battery and also show 100% battery capacity on new battery but appears as not connected to charger. Also, did an Apple Diagnosis again (with the charger connected) and this time has "ADP000 No problems found" and did some test using a macOS Big Sur on an external drive and the problem remain. May this be a faulty Logic Board? Any other advice you can give me?
von
@alejandrop15221 - Can you post a screen snapshot of the Apps main window here so I can review it.
von
Ok, I updated the post with captures from coconut battery
von
7 weitere Kommentare anzeigen
Antwort hinzufügen
Alejandro Peñafiel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 332
